vcSnapService
vcSnapService provides options for handling the position and orientation of 3D world points selected using the interactiveSnap command.
Referenced by: vcApplication.SnapService
| SnapOnCircleCenter | Boolean | RW | Gets or sets the center of circles as potential targets. |
| SnapOnCurve | Boolean | RW | Gets or sets curves as potential targets. |
| SnapOnEdge | Boolean | RW | Gets or sets edges as potential targets. |
| SnapOnEdgeCenter | Boolean | RW | Gets or sets the midpoint of edges as potential targets. |
| SnapOnFaceCenter | Boolean | RW | Gets or sets the center of faces as potential targets. |
| SnapOnFrame | Boolean | RW | Gets or sets frames as potential targets. |
| SnapOnNodeCenter | Boolean | RW | Gets or sets the center of nodes as potential targets. |
| SnapOnNodeOrigin | Boolean | RW | Gets or sets the origin of nodes as potential targets. |
| SnapOnPoint | Boolean | RW | Gets or sets points on lines and polygons, for example corner points, as potential targets. |
| SnapOnPolygon | Boolean | RW | Gets or sets polygons as potential targets. |
| SnapOnSurface | Boolean | RW | Gets or sets faces as potential targets. |
| TargetAvailable | Boolean | R | Gets if pointing at an available target in the 3D world. |
| TargetCircleCenterAvailable | Boolean | R | Gets if center of a circle is available as a target. |
| TargetCurve | list[rVector] | R | Gets a list of positions for a target curve in World coordinate system. |
| TargetCurveAvailable | Boolean | R | Gets if a curve is available as a target. |
| TargetCurveIndex | Integer | R | Gets the index position of a target curve in a geometry set. |
| TargetFaceCenterAvailable | Boolean | R | Gets if the center of a face is available as a target. |
| TargetGeoset | vcObject | R | Gets the geometry set of a target. |
| TargetLocked | Boolean | R | Gets if a target has been selected in the 3D world. |
| TargetMatrix | vcMatrix | R | Gets the position and orientation matrix for target in World coordinates. |
| TargetMatrixAvailable | Boolean | R | Gets if the position and orientation matrix for a target is available. (only valid for frame type targets) |
| TargetNode | vcObject | R | Gets the node containing a target. |
| TargetNormal | vcVector | R | Gets the normal vector of a target in World coordinates. |
| TargetNormalAvailable | Boolean | R | Gets if the normal vector of a target is available. (only valid for polygon and frame type targets) |
| TargetPosition | vcVector | R | Gets the position of a target in World coordinates. |
| TargetSurfaceAvailable | Boolean | R | Gets if the surface of a target is available. |
| TargetSurfaceIndex | Integer | R | Gets the index position of a target surface in a component, for example the faces of a cube. |
| clear | None | None | Resets the command and clears its target data. |
| execute | None | None | Runs the vcSnapService. |
| OnTargetAvailable | None | Triggered when pointer is hovering over a valid target in 3D world. |
| OnTargetSet | None | Triggered when a valid target has been selected in 3D world. |
